checking compression - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2012, 03:56 AM
Hi I am wondering if someone could help me check my compression so I can figure out with my combination if I can run on 91 pump gas or if I need to run a higher octane. If you could please help me let me know what information I need to provide. I really appreciate this I have not yet ran the motor because I am not sure what I shud run. If you let me know what specs are needed I will post asap thank you.
Old 03-18-2012, 04:41 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Enter your info and you'll get the compression ratio.
Calculator
Old 03-18-2012, 08:54 AM
techinspector1's Avatar
Wiki Edits: 326
bore
stroke
piston crown configuration, cc's in eyebrows or dish.
piston compression height
piston deck height
gasket thickness
chamber cc's
complete camshaft specs including intake valve closing point @0.050" tappet lift
Old 03-18-2012, 01:32 PM
Checking compresson
Originally Posted by techinspector1
bore
stroke
piston deck height
gasket thickness
chamber cc's
engine is supposed to be about 410 smc
Bore: 30 over
Stroke: It is a 6 inch rod
this is the piston specification that i got with the motor they are Racetec pistons. i do have a picture of what the piston looks like if you would like me to email you a pic or somthing.
The actual piston compression is 11 to 1
Engine Information
Head type: 40/60 SHIFT
Bore diameter: 4.165 in
Stroke: 3.750 in
Rod length: 6.00 in
Displacement/cubic: 408.7
Comp distance 1.125 in
Ring Info
Ring Number: AT8165 (not sure if this helps)
Rail info
Rail number: 3.845-168
Wrist Pin Info
Pin Type: chamfered
Pin number: 927-2700-51-15c
Diameter: 0.927 in
Length: 2.700 in
Piston Information
Piston type: dome diameter
Diameter 4.1620 in
Weight: 456 grams
Deck to crown thickness: 0.220
Forging type: A4123F N/C
Dome Volume: -.400 cc
Gauge point: 0.200 in
Ring groove width
Top Ring: 0.0640 in
2nd ring: 0.0640 in
Oil ring: 02180 in
Land width
Intake- depth: 0.280 in ,angle: 23.0 degrees
Exhaust- depth: 0.280 in ,angle: 23.0 degrees
im not sure wat piston deck height is but i do not piston was flush with the deck if that helps.
gasket thickness im using mls 1144 fel pro
-gasket bore: 4.200"
-comp volume: 8.9cc
-thickness: .040"
i have AFR 210 heads with 75 cc chambers
the drive train is a complete roller
The camshaft is a solid roller specs are:
lift: .630
Lobe Centers: 106
intake opens at 21 degrees close at 52 degree
exhaust opens at 54 degree close at 22 degree
intake is 253 @ .050
0.0200 is 284
exhaust is 256 @.050
0.0200 is 288
i hope i answered everything you needed. even though i probably gave you Unnecessary information but i figure id give you all the info i had. I appreciate your help.
Thanks Joseph
Old 03-18-2012, 05:28 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
I'm getting 10.96 static and 7.94 dynamic.
My dyno simulator shows spark knock at timing above 30* for 87 octane and over 32* with 91 octane.
It shows keeping timing at 30* max, just under 600HP and no knock on 91. Of coarse I may have something entered wrong somewhere.
Old 03-18-2012, 05:46 PM
O ok cool thank you yea I have no idea on how to figure this out I just want to know what it is so I know what octane I need to run if 91pump gas will not work and want to know what I should set the timng at if I can run pump gas or if it needs to be race gas.
Old 03-18-2012, 05:57 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
The program calls the knock index between 1 and 2 the "grey" area where its not sure if knock will occur.
Locking out timing at 30* shows an index less than 1 but it may go more with no issues.
Old 03-18-2012, 06:10 PM
O ok so u think if I set timing between 30-32 I may be ok on 91 with no knock? Should I lock the distributor timing out? Or what should initial be set at if I don't lock out timing?
Old 03-18-2012, 06:24 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
I think you should try it up a grade without pushing on it too hard to see if it knocks.
As I said, the simulator calls it a "grey" area. It may or may not ping. If the timing can be set up to 36* w/o knock, its good for about 20HP more.
Old 03-18-2012, 06:30 PM
O alright what makes it a grey area? Is it jus my combo
Old 03-18-2012, 08:12 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Its a grey area to the dyno simulator I use.
The simulator is not sure.
Old 03-18-2012, 08:30 PM
K thank you very much tht will be aswsome if I can run on 91
Old 03-19-2012, 11:44 PM
will i be able to run on pump gas??
I was wondering if anyone else had any other calculations on what the actual compression may be to figure out if I can run on pump gas and what timing should be set at.
Thanks
Checking pushrod length with checking springs? v8hed Engine 1 01-22-2011 06:20 PM
compression ratio compared to compression PSI squids1 Engine 14 12-28-2010 11:36 PM
Checking for Static Compression BG383 Engine 1 09-15-2009 11:05 AM
New guy checking in Jack62 Introduce Yourself 4 06-15-2009 09:51 AM
Just checking to be sure 71montebbc Body - Exterior 5 09-05-2003 08:12 PM
