checking flow at different lifts?..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2005, 10:48 PM
why is airflow checked at different cam lifts? i thought it would be checked when the cam is fully opened,no?
Old 01-03-2005, 08:30 AM
johnsongrass1's Avatar
Race it, Don't rice it!
The valves are the most torturous obstruction to proper airflow. Knowing what the air flow is around the valves can give us a better real world figures than wide open alone.
Old 01-03-2005, 10:59 AM
camaroman7d's Avatar
All cams are not the same lift (obviously) so by knowing what a given head flows at different lifts can help you choose a cam to make the most of the heads. Also the valve is only at full lift for a short period of time, while it is at "less" that full lift twice (opening and closing).
Royce
Old 01-03-2005, 10:17 PM
so,what if i do an intake? do i just open the throttle body some?then check flow, say with a vacuum gauge and a vacuum source on one end,and see if the gauge has less vacuum,will that mean it's flowing better? i am doing this just to "learn", nothing serious
