checking lift of cam w/o taking cam out tool? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2006, 02:34 AM
tiresmoke55's Avatar
PO-BOYS-TOYS!!
Last journal entry: My new 55 chevy pretty sharp
HEY GUYS
I seen in the jegs book that they make a tool that you can stick in the lifter hole and check the lift of the cam for $70 that way you can check the lift w/o taking the cam out? Do they work ok.... anywhere else a guy can get them cheaper or is there another way doing it? thanks for any info
Old 09-09-2006, 06:57 AM
The tool works great. It is really for degreeing the cam but can be used to
check the lift, such as checking for possible wear on the lobes. Proform
makes one that is identical for about 50.00. You could check the lift by
rigging a mag base with a dial indicator touching the pushrod side of the
rocker to check lobe lift & or the valve side of the rocker to check valve
lift. That way you won't have to pull the intake manifold. Don't forget that
lobe lift is valve lift divided by rocker ratio. Good luck, JohnS
Old 09-09-2006, 11:10 PM
PO-BOYS-TOYS!!
thanks for the great info.......... ILL give that a try before tearing the intake off!!!
Old 09-11-2006, 12:02 AM
How about 2 lifter bodies glued together hole-to-hole, with plungers holding them in line?
Old 09-11-2006, 02:55 AM
PO-BOYS-TOYS!!
Hmmm
Not to sure what you mean by that? lol
Old 09-11-2006, 03:06 AM
PO-BOYS-TOYS!!
A good friend of mine had a mag dial indicator, so i got it from him and the way i added it up with dividing by 1.5 'rockers' it made the cam a 560 lift.. But it does have hyd lifters in it so i guess i have to allow little for that.......the cam should be a 515/515 so with allowing for lifter travel that should be about right i guess.... were is i good place to get that Proform tool at?? also looking for a spring psi tester that checks the spring max lift w/o taking the head off....... thanks for the info!!!!
Valve Spring Tester W/o Taking The Springs Off? tiresmoke55 Garage - Tools 1 09-09-2006 07:02 AM
Olds 350 help, 2 dead cylinders & cam lift Q? 360Camaro Engine 35 07-10-2005 03:42 PM
Cam Lift Mr. GaS HoG Engine 2 11-29-2002 08:33 AM
new high lift cam and lifters dodgeboy Engine 3 04-14-2002 11:36 PM
acceptable cam lift? '66Biscayne Engine 2 03-05-2002 04:52 PM
