Checking the pickup tube? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2005, 04:14 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hello.
Im wanting to check to make sure my pickup tube is correct with my oil pan. How close to the bottom of the pan should it be and what kind of clay should I use to check it?
Should I put a layer on the pan and put the pan on, then take it back off to check it? HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 03-23-2005, 07:04 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
The best bet is to have a welding shop tack-weld the pickup to the pump cover. This will prevent the pickup from falling out. Short of that, use some Loctite Stud and Bearing Mount. Make sure the pickup is 3/8 to 1/2 inch off the bottom of the oil pan floor. Place a small chunk of clay between the pickup and the oil pan with the gasket in place to check the clearance. Make sure to install the oil pump driveshaft before bolting on the oil pump.
Luv the smell of NITRO in the morning.
Old 03-23-2005, 07:48 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
play-do will do, so will modeling clay. put some oil on the surface getting smashed so it'll not stick to the smashing surface.
thats it.
Old 03-23-2005, 08:24 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Double dot on the tack weld of the tube.
We called ourselves checking it when swapping motors and spun the block over on the stand to start the intake and heard a "Clunk"
"Oh, It was the trap door on the pan"
Luckly,the Moroso deep pan wouldn't clear the cross member and went to swap to the 'Vette pan and found the pick up tube laying in the pan.
Old 03-10-2006, 07:58 AM
clinthart's Avatar
www.project-quicksilver.com
Last journal entry: Updated photos
Moroso's website says pickup should be within 1/4" from the bottom of the pan.
https://www.moroso.com/articles/arti...utOilPans.html
Old 03-10-2006, 08:39 AM
Last journal entry: PICTURE TEST
pan
On many engines you can shine a light into the drain hole and see the location of the screen.... You can also measure the pan depth and set the sceeen from that.
As a heads up if you are running a HV pump and a steel pan make sure you weld some typ of a stand-off on the screen so the pump cannot suck the pain up against the screen...
I use a nut that is 3/8" thick....
Keith
Long or Short Tube Headers? Ray102386 General Rodding Tech 13 05-12-2011 09:16 AM
Bending Tube 62slantsix General Rodding Tech 19 06-03-2010 03:04 PM
32-34 pickup grills mehegan Introduce Yourself 1 12-19-2004 12:17 AM
Oil Pump Tube S10Fan Engine 5 03-07-2004 04:59 AM
broken oil dipstick tube guilty1 Engine 10 01-16-2003 03:17 PM
