Checking pushrod length - pattern too wide? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2012, 10:13 PM
Hello all. I'm setting up my motown heads for a 232/240 @ .050, 525/543 lift 110 lsa small base solid street roller cam in my sbc. I'm using comp 930 springs (153 @ 1.9 - actually looks like about 140-145 lbs actually seated) with lightweight tool steel 10 deg retainers, rev-kit, and summit 1.5 full roller rockers. Valves are Manley race master 2.08 int and 1.6 exh with cast iron guides and viton seals. Pushrods are engine pro 6.5" 5/16X.083.
Anyway, I'm checking for pushrod length (with about .015 lash) and i'm getting a center pattern but is is a wide sweep - more like 3/32-18" wide pattern with about 3.32+ away from the end of the valve stem. Is this too wide a pattern or am I concerned over nothing. I'm looking for a narrow pattern (more like .060-.080 max) but I'm not getting it. Any opinions or experiences appreciated. Thanks.
Old 05-07-2012, 01:59 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Use an adjustable pushrod to try different lengths. Brief instructions for making an adjustable pushrod length checking tool are here. Also there is another link (post #3) to a short Crankshaft Coalition article on valve train geometry.
Old 05-07-2012, 08:52 AM
Thanks for the reply. I also tried a slightly longer pushrod and the contact pattern is narrower but towards the exhaust side of the valve stem. So I'm trying to figure if it is better to have the wider pattern in the center or narrower pattern towards the outside. It seems the rocker needs to be higher up on the stud for the ideal pattern but the more I move the rocker 'up' on the stud the closer the roller tip is to the outside of the valve, so I'm wondering if I have the wrong rocker (too long?). I believe the center of axis on the trunnion to the center of the roller tip is about 2 1/4".
Old 05-07-2012, 09:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The general concensus is narrow is better than centered. Maybe someone else will chime in.
I'll give you a couple more links for you to take a look at in the meantime:
Mid-lift rocker theory HERE.
THREAD on geometry.
There have been many threads on this, you can use the google custom search engine at the top of the page for more on the subject.
Old 05-07-2012, 09:45 AM
Thanks. I've googled the heck out of it and get the same conflicting opinions...some say narrow-anywhere, some say centered, others say as long as the roller tip stays on the valve. I guess there will have to be some compromise at some point.
I guess if I use the mid-lift theory I would use the shorter pushrod as this starts the tip on the intake side of center then rollers over to the exhaust side at max lift....just the pattern is wider...like 1/8".
Old 05-07-2012, 09:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Ideally centered and narrowest. But as you've suspected, different rockers- even rockers having the same ratio- can also give you a different pattern. It's just that most of us cannot justify buying three or more different sets of rockers looking for the one "best" set.
But if you're stuck w/one set of rockers, my best advice is still to use a checking p-rod and use whatever length that gets you the narrowest pattern, regardless of the location on the valve tip unless the rocker is rolling off the tip itself.
Old 05-07-2012, 10:09 AM
Banned
NARROWER is better unless your roller is going off the edge. Centered is ideal but it would require different rockers or moving the stud location, but you need a narrow pattern first and foremost.
Old 05-07-2012, 10:10 AM
Thanks. Like you said, I cant keep buying new parts just to 'test' them so at some point I'll have to compromise. The rockers I have are like new with no miles on them so I'd like to make them work. I've tried the adjustable rod and it looks like the longer rod will give me the narrowest pattern (about .080)even if it is off center.
Old 05-07-2012, 01:28 PM
Depends on what the purpose of the engine is. The wider pattern in the center minimizes side load on the stem which is best for maximum stem and guide life but it compromises max lift about .005 inch. A tight pattern off to the side introduces some higher side loads onto the stem which increases the wear rate between stem and guide, but this optimizes the lift.
If you need lots of miles between rebuilds the wide centered pattern is the one to use. If you need every last pony the engine can possibly make then the narrow off center pattern is the one to use.
Bogie
Old 05-07-2012, 02:34 PM
Banned
Bogie
How does the centered wide pattern produce LESS side loading? It has much more force perpendicular to the valve stem. For wear reasons alone I choose the narrow pattern, the extra lift is just an added bonus.
I see the argument for a centered contact point, but wouldn't minimal scrub be more imporant for wear? Centered with minimal scrub is best of course, bu most people (including myself) don't want to get into moving the rocker stud.
Old 05-07-2012, 04:28 PM
dave171's Avatar
I was having the same problem and some one told me my studs may have been flexing. I put my stud girdle on and rechecked it and it helped a lot.
Old 05-07-2012, 07:28 PM
For what its worth here are a couple more pics...... the wider pattern in the center (shorter pushrod) and the narrow pattern closer to the exhaust side (longer push rod). I tried the mid lift technique but lining it up that way puts the tip of the roller on the outside (exhaust side) almost at the edge of the valve stem.
I set up a dial indicator and measured the lift (at zero lash) with both pushrods and after a couple attempts each way found that the longer pushrod gave me .005 - .010 more lift. Obviously I can't verify anything when it comes to the loading on the valve/guides either way.
Next I'll check into the rockers....I may try the comp pro magnum rollers (self aligning) as the rollers I have been testing with (1.5) have no markings whatsoever other than the ratio and barely clear the retainers. I may try to up the ratio to regain the lift I am losing with the valve lash.
ID:	65288   Click image for larger version
Old 05-07-2012, 10:33 PM
dave171's Avatar
I don't know if this will help but it's worth a try. http://www.compcams.com/Pages/417/va...-geometry.aspx
Old 05-08-2012, 07:24 AM
Banned
the diagram the supply is wrong if you're looking for minimal scrub.
Confused on checking pushrod length Silver Surfer Hotrodding Basics 1 05-04-2012 10:33 AM
Checking pushrod length with checking springs? v8hed Engine 1 01-22-2011 07:20 PM
checking pushrod length w/ hyd. lifters awoodman Engine 9 11-05-2007 06:42 AM
Pushrod length? Trav Engine 2 10-07-2003 11:50 PM
@@@Pushrod Length@@@ lakecityg Engine 1 06-21-2003 08:50 AM
