Checking Rod End Play - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2006, 05:46 PM
DaSouthWon's Avatar
I put up the tools against$300
I'm building a motor and I've got a dial indicator, Hoe do I check rod end play on a bb chevy 361959. 2 bolt main, 2 piece seals. what should the tolerances be?
Old 04-25-2006, 07:38 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
to check rod end play or side clearence just use a feeler gauge between the rods. You can use the dial indicator to check crank end play. Mount the indicator on the block and see how much the crank moves back and forth. About .007"-.011" on the crank. Side play on the rods depends on what kind of rods you got.
Old 04-26-2006, 03:38 AM
Guy Hiltz's Avatar
According to my BB chevy books the side clearance should be 0.015-0.025 minimum preferred per pair of rods.As far as crank end play goes the preferred minimum is 0.005-0.007,but I read a piece in the tech section of one of the car mags that said the wear spec by GM-the one used to determine if a part is junk or not-allows for up to 0.020.Hope this helps.
Rod Length Confusion, Short or Long??? Warrant Engine 11 01-12-2006 02:30 PM
Rod ratio RobbieRat Engine 16 11-29-2005 06:52 PM
building a 1984 camaro drag car z28camaro1984 Engine 19 04-18-2005 11:38 AM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 07:14 PM
Harmonic Balancer End Play Dans83Olds Engine 10 10-19-2003 04:08 PM
