checking transmission fluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2011, 01:32 PM
Hi all, my 66 buick skylark has a 350 chevy engine with a 400 tubo transmission, would like to know how the fluid should be checked, hot and running in neutral , hot and running in drive, hot and not running, cold and not running,have had all these different answers given to me . Also does it hurt to have the fluid over full and if so what kind of problem would this cause ?
Old 11-06-2011, 01:36 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I alway's check mine warm and running in park, I will start it up let it warm up then switch through the gears then place it in park and leave it running and then check. Some guy's will do a cold check first then warm it up and re-check. JMO I have also done the cold check then warm check. .
Cole
Old 11-06-2011, 02:20 PM
user151's Avatar
I check my auto trans after coming home from a drive, then I shift through the gears (R D1 D2 etc) then put it in park and check it hot.
You should not run it overfull, it can cause leaks, foamy fluid, slippage...
best to run it between the low and full marks (when checked hot).
Old 11-06-2011, 03:35 PM
gmc1990rodder's Avatar
I'm along with both guys here too. Start the engine get it to normal operating temp. and run thru the gears a few times place it in park then check it!
too much transmission fluid bad? wiser626 Transmission - Rearend 6 01-31-2010 04:28 PM
Transmission fluid hot jjrkjnoslen Transmission - Rearend 25 11-05-2009 03:20 PM
Transmission fluid for T-350? bentwings Transmission - Rearend 3 09-10-2007 02:56 PM
Does transmission fluid ever go bad?? schnitz Transmission - Rearend 3 09-15-2005 06:46 PM
Transmission Fluid c-4 85stangboy Transmission - Rearend 9 12-21-2004 07:15 PM
