The best way I found to check for leaks is to spray carb cleaner around gaskets, hoses, etc. If the engine revs up, you have a leak at that point.
If your intake is cracked, yes, it can affect vacuum and make for a poor running engine. |
HERE is a vacuum gauge reading guide. THIS is another one.
Spraying WD-40, etc. around suspected vacuum leaks is often recommended. You can sometimes hear a vacuum leak, though this isn't too common. Check all the hoses and accessories, you can disconnect some of them at their source and plug the openings to se if the idle speed changes. Be careful, though- removing some vacuum lines can set a code. No biggie if it does, just making sure you're aware of the possibility. |
| Mysterious vacuum leaks. | Hippie | Engine | 4 | 12-01-2009 08:10 AM |
| vacuum leaks and vacuum gauge | GMR | Engine | 7 | 09-12-2008 07:14 AM |
| vacuum leaks | JG700 | Engine | 9 | 06-25-2007 06:38 PM |
| Vacuum leaks | himmelberg | Engine | 4 | 12-11-2005 01:38 PM |
| Checking for vacuum leaks | gpeak | Engine | 3 | 10-20-2003 07:18 PM |
