-   -   Checking for vacuum leaks (http://www.hotrodders.com/forum/checking-vacuum-leaks-26158.html)
gpeak 10-20-2003 05:09 PM
JUst wondering. Is a thick towel over the carb. a good test for vacuum leaks? I have done this before and if the engine dies when you do it, means there are no leaks. But mine still runs like it has a leak some were.
mikeweyman 10-20-2003 05:50 PM
Is there a problem with thge car? or were you just wondering??
gpeak 10-20-2003 06:07 PM
Yes! It runs rough like there is a vacuum leak.
302 Z28 10-20-2003 07:18 PM
If you have a vacuum leak when you restrict airflow into the carb, the engine will speed up. A quick method to check for vacuum leaks at the intake maifold is to run water along the intake-head joint.
Vince
