Checking for vacuum leaks - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2003, 05:09 PM
gpeak's Avatar
JUst wondering. Is a thick towel over the carb. a good test for vacuum leaks? I have done this before and if the engine dies when you do it, means there are no leaks. But mine still runs like it has a leak some were.
Old 10-20-2003, 05:50 PM
mikeweyman's Avatar
Last journal entry: 2 years later
Is there a problem with thge car? or were you just wondering??
Old 10-20-2003, 06:07 PM
gpeak's Avatar
Yes! It runs rough like there is a vacuum leak.
Old 10-20-2003, 07:18 PM
302 Z28's Avatar
If you have a vacuum leak when you restrict airflow into the carb, the engine will speed up. A quick method to check for vacuum leaks at the intake maifold is to run water along the intake-head joint.
Vince
