Cheep metal bender - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2009, 06:49 PM
Cheep metal bender
Hello every one. I am new to the fourm and I am look to make a cheep metal bender for my shop. I am currantly working on my Sons 82 Capri Black Majic and need to bend some metal for the floor and to dress up under the hood.
Old 09-28-2009, 08:24 PM
life is a temporary assignment
Here's one I built.. 20 tons..
ID:	40940   Click image for larger version
Old 09-28-2009, 09:59 PM
OLNOLAN's Avatar
Cheap Sheet Metal Bender
Well, its not as cool as New Interiors(real nice Randy) I use two pieces of angle iron about 3 feet long in my big bench vise. Get metal marked and positioned between the angle iron, tighten it up, get the bend started by hand, the use my big rubber mallet(about 3 lbs) to get the final bend. I've used this method to fabricate lots of custom brackets, sheet metal covers, etc. If you bend it out slow and move side to side you can do alot with the angle iron bender. You did say "cheap". olnolan
Old 09-29-2009, 11:20 PM
Thats real interesting, think I might have enough steel around to make one. thanks for the ideas. any others would be welcome.
"Basics of Basics" Molding repair / metal finishing MARTINSR Body - Exterior 6 07-09-2009 10:47 AM
epoxy or etching primer over bare metal? pineknot Body - Exterior 21 03-16-2007 08:53 PM
sheet metal work robs ss Body - Exterior 2 11-22-2006 05:19 AM
metal finishing pictures sevt_chevelle Body - Exterior 2 11-14-2006 07:09 PM
Bare metal prep greenmachine Body - Exterior 7 10-27-2004 07:57 AM
