Cheese Grater? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-07-2009, 10:06 PM
Wiki Edits: 31
We use them all the time in the alpine ski industry... you can use it with P-tex ( base repair compound that is polypropolene plastic ).. to file off ski binding hole plugs, for when you do a remount on an old pair of skis and need to fill the holes.. filing epoxy from bases after doing a patch... lots of stuff we use them for... of course I bet there are some ski specific tools we could probably use in automotive world
  #17 (permalink)
Old 04-08-2009, 11:23 AM
CQNRQY
Cheez Pleez ?
They have two types. A flat one and a curved one . And of course the handle to hold it. (totally useless and in your way) . The one that always worked for me it the past was the one with the curve. Used it holding the ends that turn up and are intended secure it to the handle. Like I said before, good for a mud job or some plastic lead sled work
My Wife just thought of another use...
... in the kitchen when grating the cheez toppings for my next pizza
  #18 (permalink)
Old 04-08-2009, 11:50 AM
CQNRQY
Originally Posted by crownver
I believe they are really a woodworking tool. My dad had one years ago for working with wood.
Hey, lookee what I found
Name:	mystery tool 001.JPG
  #19 (permalink)
Old 04-08-2009, 11:59 AM
speede5's Avatar
go fast, turn left!
I have one for shaving down drywall sheets.
If you are using one on bondo you are either using too much or you are trying to shape some funky panels ala Ed Roth.
I would say though, if you happen to accidentally over apply your bondo and end up with some ridges it is better to let it set up and cut it down with a grater than over work it while it is drying to try and smooth it out. Once you get the hang of applying filler this tool will more than likely end up in the bottom of your box.
cheese cloth paint job help th350mark Body - Exterior 21 04-06-2009 03:28 PM
Cheese grating filler yeepman2 Body - Exterior 26 03-26-2007 12:23 AM
Don't like swiss cheese msc66 Body - Exterior 16 09-20-2004 11:30 AM
How can you be nude if you are covered in nacho cheese? CrashFarmer2 Hotrodders' Lounge 10 08-09-2004 07:20 PM
PC/Wine & Cheese crowd moving in. FASTCHEVY Hotrodders' Lounge 21 05-12-2004 11:11 PM
