Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chemical dip for engine blocks
Old 06-27-2006, 06:22 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Castrol Super Clean may work pretty well. Believe it or not one of the best cleaners is heated automotive antifreeze. It may be your cheapest route also. If you choose to try it you need to heat it to about 200 degrees and it needs to be circulated, works wonders on aluminum too.
Vince
