Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chemical dip for engine blocks
Old 06-27-2006, 09:54 AM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
Kleen Flo carb and metal cleaner works well, but is expensive(and nasty fumes). B4 you go ahead, I'd look into the environmental requirements for this. Up here, all soak tanks have to be double walled, safteyed, ect., b4 you can use them. If you are doing this at home, and you need to heat the solvent, you may affect your homeowners insurance.
