sounds like red devil lye almost to me, if it don't eat the block the electric water heater element will most likely survive the lye, anyway a buddy of mine did it that way he says. ED
It's funny you said something about the Red Devil lye, my Neighbor that I mentioned had it laying around and showed it to me. Now the lye is only one part of the chemical make-up. Trying to figure out what the rest of the chemicals are for. He said that Sodium Hydroxide(lye) is as cheap as dirt and that he can make the formula for me if Zep wants to much $$$$$.
I thought the water heating element was aluminum and copper. Only installed them never had to change an element. Anyway when aluminum mixes with the lye it starts to eat it and give off hydrogen. Sounds dangerous. Hydrogen and electric don't mix very well, every heard of a battery exploding. I just called a Pluming supply shop, they said that the covering on the element is steel. All sounds good. Last edited by oldsmo; 06-29-2006 at 01:12 PM. |
Olds, Nothing high tech about that formula that's what I was talking about earlier and it has been used for years, it does work but it really should be heated to get it's full potential. Now for the bad part, this stuff is DANGEROUS! and the hazards are not to be taken lightly. It can cause severe skin burns and blindness so if you do decide to use this stuff be very careful with it. Also it is not something that you can just pour out in your driveway or someplace similar to get rid of, it is considered hazardous waste. It can be used safely with a bit of caution but it is not something that should be used with a poorly designed dip tank since a spill in your garage or near your house of a quantity large enough to dip an engine block in could be a major problem. BE CAREFUL with this stuff!
Well Zep wants 300$$$$ for 125lbs(their smallest) container. Does that sound like allot for basic everyday chemicals. |
That may not be all that much if you are using that material all the time..But then a lot of those kinds of chemicals are only sold in industrial quanities to professional users..
Sam
That is industrial chemicals and I am surprised that you did not run into problems other than cost in buying the stuff. The cost reflects the fact that this is not something sold on a large scale (comparatively) and overhead such as HAZMAT handling etc. There is nothing high tech about dip tank fluid and you should be able to mix your own, shops did it for years. if you are serious about doing this I will check with a Friend of mine and see if I can get a list of what you need and maybe some sources but the main ingredient is Sodium Hydroxide which may not be so simple to buy but then maybe it will be easy to get, we will find out
Ok that was easy enough, All really need is the Sodium Hydroxide (caustic soda) but to make a better solution he said you could add the Sodium Carbonate (soda ash) in the amounts shown for the chemical solution you mentioned. I did a quick search and found that the Sodium Hydroxide is not at all hard to acquire nor is it expensive.
I think you will find every thing you need here.www.chemistrystore.com/Sodium_Hydroxide.htm Also see http://www.chem.tamu.edu/class/major...mhydroxide.htm It would be a REALLY good idea to use a stainless steel tank and you do need a heater but for agitation he said that a lot of people simply use a tube with small holes coupled to an air line so that it bubbles from the bottom of the tank. I can not stress strongly enough to BE CAREFUL WITH THIS STUFF!!
| The Following User Says Thank You to oldred For This Useful Post: | ||
BadHabitSS (05-30-2013) | ||
People at my job have to deal with hazardous waste on a regular basis--I would want NO part of that
Proper chemical disposal is cost prohibitive to anyone without a 6 figure income. Toss the block & head into the pick-up and take em to an engine builder for cleaning. My opinion Bryan |
zep makes a chemical called caustic soda. works great but you must heat it. It's made for jet wash tanks you see in most engine shops.Mixs with water so much to so many gallons.
Magnetic particle removal
I have a motor that had a pan magnet disintegrated and put particles throughout the motor especially in the main bearings. Have pressure washed the block, heads, and crank. Bearing get killed at about 1000 miles and I'm getting ready to replace cam bearings with a wash and flush this time also.
I'm asking for any ideas on how to remove any remaining magnet material and or prevent it from entering the oil pump. The motor has extensive machine work done to it or I'd toss the whole mess. |
Bryan, Makes an excellent point that should not be overlooked, you are going to have the dickens of a time getting rid of that stuff when the time comes, $$$. If you just dump it some place
you could very well face a hefty fine or jail time if it is found and traced backed to you, this is serious business!Swvalcon, Caustic soda and Sodium Hydroxide are just two different names for the same thing and it is the same chemical we have been discussing, you are right it will work great all by it's self if mixed in the correct amount of water and heated but the heated mixture should also be agitated during use. Gary, What kind of block? After a through hot tank cleaning you might try cleaning the oil passages with a small wire brush (gun cleaning kit? Maybe tools made just for this?). You probably should remove the plugs at the end of the cam galley and push the brush/swab all the way through if possible. Even the tiny passages are drilled and thus straight so I think you will probably be able to clean all the passages with a bit of effort and due to the fact that this material, by it's nature, will tend not to wash off I think you are doing the right thing. Last edited by oldred; 07-09-2006 at 08:32 AM. |
With regards to getting rid of the stuff when you're done...
IIRC, Sodium Hydroxide is a strong base. If you mix a base with an acid, you end up with water and a salt. Might want to check with a chemist, but you may be able to neutralize the sodium hydroxide with the right acid to render it harmless. My chemistry is a little rusty, but I think hydrochloric acide (muriatic acid) might work. You would end up with salt water (full of whatever you cleaned out of the block). Probably dont want to pour a huge amount of salty water down the drain at once, but you could get rid of it without the danger of sodium hydroxide and its not going to burn or explode. Would likely have to be done in small batches with extreme care. A possible problem might be the acid's reaction with whatever came off the block. Check with someone who knows for certain. |
| Recent Garage - Tools posts with photos |
| just passed the 1000 dead mark | bullheimer | Off-Topic | 54 | 05-03-2009 09:31 PM |
| chemical dip in los angeles area. | 6T3 1/2 GALAXIE | Body - Exterior | 0 | 02-17-2006 12:25 AM |
| Soda Blasting VS. Chemical Dipping | iwanta32fordtruck | Body - Exterior | 4 | 12-21-2004 02:09 AM |
| chemical dip | streetrodder31 | Body - Exterior | 11 | 12-01-2004 03:47 PM |
| Chemical dip | arborlis | Body - Exterior | 0 | 01-23-2004 08:45 PM |
