chemicals to deaden gas fumes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2011, 08:24 PM
i use to work in a radator shop and we did tank repair.there was a white milky chem my boss used to deaden the fumes with he would put in about a cup and run air to it. does anyone know what it might have been and where to get in
Old 04-06-2011, 08:43 AM
The liquid is called an emulsifier and here's one source:
http://www.columbussupply.com/products/?productid=253
Old 04-07-2011, 03:30 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Put a cup of it- where? Into the vats themselves? How was air introduced into this? Maybe some more info on exactly how this substance you're asking about was used might help.
Radiator shops use a variety of chemicals/acids, etc. like hydrochloric and zinc chloride fluxes, sulphamic acid for hard water, lime, and scale build up, oxalic acid can be used to remove rust. They ALL can give off fumes.
Old 04-08-2011, 09:27 PM
thank you not quit sure we would pure about a cup in the gas tank then stick a small low pressure air line in the liquid for about an hour after welding had to get it out or the mech would have a fit when the car would not start
Welding safety/Cleaning chemicals oldred Body - Exterior 16 07-30-2009 03:16 PM
welding and chemicals BAD JUJU!!!! javracer General Rodding Tech 2 07-27-2009 12:06 PM
Welding Fumes 62440 General Rodding Tech 12 07-10-2007 10:55 AM
tire softening chemicals? jackflash Hotrodding Basics 4 02-16-2006 06:49 PM
striping paint with chemicals 6speedwagon Body - Exterior 1 03-14-2004 10:54 PM
