Cherry Bomb glasspacks - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2009, 09:43 AM
Steven
I have a 1958 Chevy Apache with a 350sbc under the hood. 4 barrel carb, edelbrock valve covers, and one ****ty *** exhaust. yes its loud for me but the dual 1" straights are not gonna cut it. They have some mufflers which are pretty warn out by now. I am now looking to upgrade aka over haul the exhaust. OH I WILL EB WELDING THIS ALL UP MYSELF.
I am thinking my 4-1 headers with 2" tubing for the exhaust and glasspacks under the bed. then have the tips come rite under the roll pan so you will not see much of the tips.
what does everyone think about this? should i go with 2.5" tubing for the exhaust?
I have tons of Noob questions lol.
Old 03-13-2009, 10:24 AM
DoubleVision's Avatar
Your engine info is somewhat sketchy but either way I would use the 2.5 pipes. I would also weld in a X pipe.
Old 03-13-2009, 10:44 AM
Banned
Taht depends a lot on cam duration split. If its a single pattern go with the 2.5" if its a stock or a dual pattern go with 2".
Old 03-13-2009, 12:21 PM
Steven
Explain skatchy if you will, I am noob status to V8 motors and just know very very little to be honest. What is the point of a X pipe exactly? Cam duration split?
Old 03-13-2009, 01:38 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Do some research on glasspacks. Some of them flow terribly and will restrict the exhaust no matter what size you use. Others are very free-flowing. But (as with any straight-through muffler) the more they flow, the louder they are. Getting adequate flow might mean they will be VERY loud with a lot of interior noise.
Cheap parts store glasspacks are loud and flow poorly. Companies like Heartthrob have several glasspack designs that range from poor flow/quiet up to really high flow/really loud.
Old 03-13-2009, 02:34 PM
techinspector1's Avatar
Wiki Edits: 326
An X pipe will help to equalize the exhaust pulses from one bank of the motor to the other, resulting in a better sound than either no X pipe or an H pipe. Install the X after the header collectors but before the mufflers.
The key to a good sounding glasspak system is to use 36" long mufflers. Anything shorter will give you a raucous, "blatty" sound. Get the mufflers with louvers punched into the inner pipe instead of plain round holes and install the mufflers with the louver openings facing the front of the truck. If they have baffles in them, use a 4-5 ft. length of metal pipe to bang the baffles out. They are just tack welded in.
With a warmed over 350, 2" or 2 1/4" will be fine, but while you're doing it, you may as well go to 2 1/2" if you plan further improvements to the motor.
Your plan to extend the pipes to the rear of the truck sounds well-thought-out to me. I've seen fellows terminate the pipes under the truck and the exhaust pulses will reverberate against the sheet metal under the truck. This will set up a drone in the cab that will sound cool for about 10 minutes. After that it will make you nuts and you won't want to drive the truck any more.
Old 03-13-2009, 03:31 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
http://www.jegs.com/p/Moroso/744819/10002/-1
I have these on my car 2 1/2 in and out Shorty headers true duels.
They do drone at 60 but I think thats more due to the short exhaust than the muffler.
Good thing is they wont blow out like glass packs.
http://www.youtube.com/watch?v=GnDrDs225EI
I have some exhaust resonant tips that should help with the drone.
Old 03-14-2009, 09:37 AM
Steven
I think I'm gonna throw some spark plugs in the mix for a little flame thrower fun too. I can't wait to get this done! I better go pick up some fence tubing.
Old 03-14-2009, 04:28 PM
BowTiePride's Avatar
Chevy to the death!
What're the benefits and drawbacks of running an X pipe vs. an H pipe? remeber to keep the bends paralell on both sides, and keep everything equal length
Old 03-14-2009, 05:23 PM
H & X pipes increase power,give a smoother sound(ever hear straight pipes that dont crackle like firecrackers in a tin can? Mine dont),they also reduce the noise.
downside possibility of clearance issues.
Shane
Old 03-15-2009, 07:14 PM
Steven
Now I learning to weld and bend metal like a pro. So if the pipes are 2.5" then what size tubing should I use to make the headers?
Old 03-15-2009, 08:23 PM
Wiki Edits: 326
1 5/8" if you plan no further improvements to the motor. 1 3/4" if you have plans for further improvements.
Cherry Bomb Turbo II mufflers: Are they any good? Jyzoz Engine 8 05-20-2008 05:00 PM
cherry bomb pro 47chevrolet Engine 4 02-28-2007 09:45 PM
cherry bomb 47chevrolet Engine 12 02-20-2007 08:37 PM
Cherry Bomb Mufflers CrazyRoyExhaustfreak Engine 3 10-12-2006 12:51 PM
Alright...I JUST don't get it?! Weimer Hotrodders' Lounge 295 02-18-2003 06:46 AM
