Chev 350 Oil Pan Gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2005, 09:04 PM
I have what Mortec says is a 69-80 350 ( casting number 3970010). What determines whether it uses a thick or thin front seal on the oil pan gasket? I want to use a 1 piece oil pan gasket probably Fel-Pro or Milodon. I have to order the gasket so I want to know before ordering the wrong part. Is it the oil pan that is the determining factor? I will use OEM or Slam Guard.
Thanks,
Bill
350 Chevy oil pan leaking gasket Ed Baltera Engine 14 08-05-2012 01:17 PM
Pan Gasket MI2600 Engine 1 05-07-2005 08:45 AM
Rear of engine oil leak 350 western star Engine 5 07-13-2004 03:32 AM
Milodon oil pan...7 qt w/ filter or + filter? Finmike Engine 6 07-05-2004 10:44 PM
oil being sucked threw the pcv valve on my 350 sb.. Robbie Engine 23 05-08-2004 09:12 AM
