chev 350 rebuild final stages - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2008, 05:56 PM
i have a 1984 camaro z28 and built a 350 to replace the blown up 305 that was in it. the engine is completely built except that i don't know where the vacuum lines, distributor advance control, EGR, PCV ect. lines/valves go on the manifold and where certain things hook up to the carb. i went to the Chevy dealership to ask for a diagram but they couldn't help much. does anyone know of any diagrams or have any information about the valves/lines that are on the manifold/carb?
Old 03-29-2008, 06:08 PM
Jmark's Avatar
It will depend on what carb and intake. What's going on it?
Old 03-29-2008, 06:15 PM
RippinRon's Avatar
Does this help?
Old 03-29-2008, 06:42 PM
i kept my stock 305 intake and heads on it for now but i did a bunch of work on the heads and the quadrajet that was on it
Old 03-30-2008, 11:07 AM
Ozz1967's Avatar
Air Force Guy
Camaro Vacuum lines 82-92
Check the second post down, it has a link to a word document that shows every vacuum line configuration for every engine ever put into an 82-92 Camaro. If all you have done is installed a 350 and have kept your stock heads and carb (not that you didn't have any work to them, but they are the originals otherwise), the vacuum line conficuration will be identical to the one for the engine that you pulled out. Hope this helps!
350 Chev cooling Ricardo Engine 20 02-06-2006 07:14 PM
Big chev 454 and small chev 350 bolt pattern boneyard Buick Engine 4 01-18-2006 09:07 PM
350 rebuild grandprix601 Engine 2 09-18-2005 09:06 PM
350 Rebuild 84camaro350 Engine 7 03-15-2004 07:59 AM
350 rebuild ideas pls 56wagon Engine 6 03-04-2002 07:41 AM
