Chev 350 rebuild starting/timing issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 12:35 AM
I rebuilt my 1980 350 with Keith black pistons, e-tec heads making 9.7-1 , rolling thunder cam I234* E238* , MSD street fire distributer, air gap intake, 650 ede carb. What kind of initial idle timing should I have? With vac advance disconnected and plugged this engine will not start unless i give it a crazy amount of advance (about 30 degrees I think) then it will run till its warm and dies out. I have tried everything between 10 and 18 degrees. Do I need to modify the centrifugal advance in the distributor?
Old 04-21-2013, 01:20 AM
Proud LOSER
Have you verified TDC ? If so, your timing isn't the issue, it should still start and run without that much advance, and shouldn't stall after warm up. What the pn# for your cam? How old is the Carb, pn# for that too. Has it been touched? Assuming those are your "at 50" numbers then I would try it at 24 initial, 34-36 total, no, you can't use your stock timing curve, it must be modified to get a 10 curve.
Old 04-21-2013, 01:23 AM
Proud LOSER
Nvrmnd, edelbrock roller, found it. Try the 24 at initial and see what it does. I still think its a Carb issue tho.
Old 04-21-2013, 01:37 AM
It's a ede 1406 carb. So how would I get A constant 10 degrees out of my distributor if that's what you mean, is there a way to lock it into place?
Old 04-21-2013, 01:39 AM
Don't kno how old the carb is but it ran fine before I did my mods
Old 04-21-2013, 01:50 AM
techinspector1's Avatar
Wiki Edits: 326
bygddy beat me to it, but here is the correction procedure for setting up the static ignition timing so that you can time the motor with a light.....
http://www.crankshaftcoalition.com/w...op_dead_center
I'd bet a nickel to bucket of dog doo that your damper is junk.
Personally, with the cam you're using, I'd use 16 at the crank when you get the whole mess sorted out, 20 in the weights with a slow chamber, 18 in the weights with a fast chamber, all timing in by 2800.
Old 04-21-2013, 09:45 AM
Read this Wiki article on Limiting or locking the mechanical advance mechanism. http://www.crankshaftcoalition.com/w...EI_distributor The Msd Street Fire will be set up just like the GM HEI. Adjust the initial timing after you have adjusted the idle transfer slot on the primary throttle blades. Use enough initial timing so the engine will idle around 800-850 rpms. If the initial timing is 24* BTDC you will need to limit the mechanical advance to 12*-14* BTDC for a total of 36*-38*. You will then have to limit your vacuum advance to 12*. The Crane Adjustable Vacuum Advance Kit is the best to use IMO. Be sure to read the Wiki article it has all the information you need in it.
Old 04-21-2013, 09:58 AM
vinniekq2's Avatar
I agree with bygddy/tech, 20 ish static timing.I tend to use a couple extra s with a hydraulic flat tappet than a solid.Your engine will tell you what it likes.
buy a strip kit for your carb
350 timing
i am having starting issues with my 350 83chevytruck Engine 3 04-12-2011 09:27 PM
sb 350 timing issues MaineHandyman Engine 3 09-08-2009 08:19 PM
350 Chev Rebuild SICOA 10 Introduce Yourself 1 07-27-2004 07:13 PM
rebuild chev 261: timing gear marks? Macman Engine 1 07-27-2004 01:14 PM
350 chev rebuild richpandolfi Engine 1 09-26-2003 11:09 PM
