cHEV 4.3L Bore size..compare to SBC 350 (both stock) - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2006, 11:29 PM
boneyard Buick's Avatar
Hey guys
just wondering:
Are pistons for a stock SBC 350 exactly 4". i got some keith black pistons here and were only used for 500k i measured and they were 4" just wondering what the stock bore size is for a stock 350
and do the 4.3L chev and 350 share the same bore size??? Will i be able to use the 350 pistons?
Ryan350 :thumbup:
Old 09-25-2006, 04:02 AM
BOBCRMAN@aol.com's Avatar
Yes, the bore sizes are the same. The 4.3 is in reality a modified 350 with two cylinders whacked off.. Watch the piston weights tho. 4.3's used several different weight/styles of pistons. Unless re-balanced. The wrong combo will get you a shaker!
Old 09-25-2006, 10:49 AM
thanks for the reply, i got another question. I have some stock 350 connecting rods with full floating wrist pins on the pistons FROM the 350. I was also wondering if i will be able to use these rods as well on the 4.3.
Also, i have a gear drive from my 85 smallblock 350, my 4.3L is a 1989 and it has roller lifters. I was wondering if my gear drive would work on it, i know on v8 roller cam/lifters the bolt up is different for the timing chain and late model doesnt work with newer model v8's, but i was just gonna ask to see if anybody knew off hand if it would fit or not. Thanks
Ryan350 :thumbup:
Old 09-25-2006, 06:13 PM
4.3 rods use different size bearing. 350 rods won't work. Neither will the gear drive. Bolt pattern is smaller and 4.3 has a thrust plate. Not compatible with early gear drive.
Old 09-25-2006, 07:07 PM
are the wrist pins on the 4.3 and 350 the same?
Ryan350 :thumbup:
Old 09-25-2006, 07:29 PM
yes. stock SBC size
Chev 4.3Liter Bore size.. and chev 305 or 350 bore boneyard Buick Engine 9 08-08-2006 10:55 PM
Cam grind for a 350 sbc 30coupe Engine 2 04-07-2003 07:29 PM
Most HP/Comp for SBC stock bottom end? bigmark Engine 8 04-04-2003 06:11 AM
350 sbc HP/TQ question stfinney Engine 10 03-04-2003 02:49 PM
stock 78 sbc 350 - how much power? andybird Engine 7 01-21-2003 12:48 PM
