Chev 6.5 Turbo - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2002, 11:58 PM
Post Chev 6.5 Turbo
I have a Chev 1994 6.5 Turbo,what can be done to it more performance. 120,000km and is it common for fuel pump under the driver side to go often?If so is there a better fix than replacing with a new GM part.This is my 4th one and not under warranty...
Old 12-15-2002, 06:36 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
Propane injection or a larger turbo are two obvious ways I can see to help out a Desiel. Both of those will require some injector pump work to get more fuel.
BUT, I have heard that when those things are hot you can pee on the rear wheel and they will crack a head. SO, if I were you I would not push it.
Chris
