The bell housing mount surface should be the same between the 2 different transmissions. Also compatible are the turbo 350, 350C, 400, and a few others. You will need to have a way to control the lock up torque converter. Hope this helps some.
I read somewhere that a guy used a lighted switch that reads "O/D" from a Nissan Maxima and wired the TC lock-up thru this switch and I think the brake switch so it would shut off if you hit the brakes. You just had to remember to shut it off manually if you reduced speed down to city driving or the engine would lug real bad and kind of remind you.
4L60E and 700r4(and well any gm trans) will have the same bolt pattern, except for BOP and caddy v-8's as long as both are from the same degree bellhousing engine 90 degrees(v-8, 4.3L, 229, 200, straight sixes or 60 degrees all GM 4 cyl, 2.8L, 3.1L, 3.3L, 3.4L, 3800, AMC 2.5L, etc. |
| I am looking for an early hemi transmission adapter | toddwallace | Engine | 6 | 01-13-2009 03:24 PM |
| Early Hemi Projects | Hemi Bob | Introduce Yourself | 3 | 11-27-2006 09:11 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
| 605 conversion for 57 chev | foreverbowtie | Suspension - Brakes - Steering | 3 | 06-18-2003 08:26 PM |
| 51 Chev Power Steering Conversion | olestufsafl | Suspension - Brakes - Steering | 0 | 12-30-2002 12:55 PM |
