Chev blazer tranny replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2005, 03:47 PM
tbirdscott's Avatar
stuff'n things'n whatnot
alright a buddies tranny finally gave out on him in his 1987 blazer or jimmy or whatever its a 4X4 auto 4.3L and hes got an 86 blazer parts truck 4X4 auto 3.8L what I need to know is if the tranny from the 3.8 will bolt up to the 4.3. I know the 4.3 shared the sbc bolt pattern (right?) but I dont know about the 3.8, the trucks are in two different locations and i'm too lazy to go look at them any help is appreciated
Scott
Actually the 86 might have the 2.8L I think that screws everything up.....
Old 06-02-2005, 04:57 PM
It must have a 2.8L in it which is a 60degV6. Those use the same bell housing pattern as the 4 cylinder engines. The 4.3L is a 90degV6 and shares the pattern with the small and big blocks like you said.
Old 06-03-2005, 02:04 AM
tbirdscott's Avatar
I dont know, did the blazers even come with the 3.8? I guess if it has the 2.8 were SOL then. Would a full size p/u tranny from a V8 work then? I know nothing of chebbies
Old 06-03-2005, 10:45 AM
GM never put a 3.8 in an S-series truck/blazer. The only V6's were 2.8L or 4.3L
Old 06-03-2005, 05:00 PM
tbirdscott's Avatar
Yup checked today and the 86 has a 2.8 so thats not gonna work, anyone know if the tranny out of a fullsize would work? I might be able to snag one of those
Old 06-03-2005, 06:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the back end of a 4x4 700r4 is the same from a V-8 tranny to the small V-6 tranny. It will bolt to the transfer case...
Chev 350 tranny reclusej Transmission - Rearend 9 11-02-2004 09:49 PM
Chev 350 tranny reclusej Transmission - Rearend 0 11-01-2004 02:38 PM
K5 Blazer tranny antirice Transmission - Rearend 1 12-09-2002 04:53 PM
chev 350 tranny bettylew Transmission - Rearend 1 11-10-2002 05:48 AM
What's a good tranny replacement for my 62 Pontiac Catalina? Albert Wallace Transmission - Rearend 5 04-10-2002 07:16 AM
