Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chev starter drilling template
Old 11-26-2012, 01:48 AM
junior stocker's Avatar
junior stocker junior stocker is offline
ALL 283's come with provisions for block mounted starters already drilled/tapped in the block. Been this way since 1957 when the "optional" Turboglide transmission came online. It was an all aluminum transmission, and required a block mounted starter. I'm betting you have a 265 block, and if that's the case, you can't drill/tap it; there's not enough of a "pad" for a starter to bolt to. BUT, you can buy a starter motor adapter plate/ring from any of the Tri-Five Chevrolet vendors (about $100.00) that allows you to use a 168 tooth flexplate, the 3 bolt "bellhousing mounted" starter motor, AND any late model aluminum automatic transmission from Chevrolet. Post the casting number of the block just to verify what you have. Butch/junior stocker.
The Following 2 Users Say Thank You to junior stocker For This Useful Post:
cobalt327 (11-26-2012), cruizincoupe (11-26-2012)
