-   -   chev starter drilling template (http://www.hotrodders.com/forum/chev-starter-drilling-template-226443.html)
cruizincoupe 11-23-2012 11:40 PM
I want to use a turbo 350 behind a early 283. where can I find a template to drill starter mounting holes for a late model starter ?
C-10 11-24-2012 11:30 PM
Gonna have to make one. I'd reference off the oil pan rail bolt centers. If you smack a late starter (diag bolt pattern) up there with one bolt tight as a jig there's no telling where the thing would be pointing.. parellel.. plumb.. perpendicular.. conky-wonkus.
Can't say I've run across this.
Best of luck.
junior stocker 11-26-2012 01:48 AM
ALL 283's come with provisions for block mounted starters already drilled/tapped in the block. Been this way since 1957 when the "optional" Turboglide transmission came online. It was an all aluminum transmission, and required a block mounted starter. I'm betting you have a 265 block, and if that's the case, you can't drill/tap it; there's not enough of a "pad" for a starter to bolt to. BUT, you can buy a starter motor adapter plate/ring from any of the Tri-Five Chevrolet vendors (about $100.00) that allows you to use a 168 tooth flexplate, the 3 bolt "bellhousing mounted" starter motor, AND any late model aluminum automatic transmission from Chevrolet. Post the casting number of the block just to verify what you have. Butch/junior stocker.
cobalt327 11-26-2012 06:33 AM
Good info, JS.
A short description of the plate for using the bellhousing mount type starter is here.
Adapter http://www.crankshaftcoalition.com/w...ptor_plate.jpg
Starter used w/adapter http://www.crankshaftcoalition.com/w...nt_starter.jpg
cruizincoupe 11-26-2012 12:03 PM
THANK YOU !!!!! to C10 ,JUNIOR STOCKER and COBALT 327 for your replies to my question about starter mounting holes on an older 283. you have been most helpful. CRUIZINCOUPE.:)
