chev starter drilling template - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2012, 10:40 PM
I want to use a turbo 350 behind a early 283. where can I find a template to drill starter mounting holes for a late model starter ?
Old 11-24-2012, 10:30 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Gonna have to make one. I'd reference off the oil pan rail bolt centers. If you smack a late starter (diag bolt pattern) up there with one bolt tight as a jig there's no telling where the thing would be pointing.. parellel.. plumb.. perpendicular.. conky-wonkus.
Can't say I've run across this.
Best of luck.
The Following User Says Thank You to C-10 For This Useful Post:
cruizincoupe (11-26-2012)
Old 11-26-2012, 12:48 AM
junior stocker's Avatar
ALL 283's come with provisions for block mounted starters already drilled/tapped in the block. Been this way since 1957 when the "optional" Turboglide transmission came online. It was an all aluminum transmission, and required a block mounted starter. I'm betting you have a 265 block, and if that's the case, you can't drill/tap it; there's not enough of a "pad" for a starter to bolt to. BUT, you can buy a starter motor adapter plate/ring from any of the Tri-Five Chevrolet vendors (about $100.00) that allows you to use a 168 tooth flexplate, the 3 bolt "bellhousing mounted" starter motor, AND any late model aluminum automatic transmission from Chevrolet. Post the casting number of the block just to verify what you have. Butch/junior stocker.
The Following 2 Users Say Thank You to junior stocker For This Useful Post:
cobalt327 (11-26-2012), cruizincoupe (11-26-2012)
Old 11-26-2012, 05:33 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Good info, JS.
A short description of the plate for using the bellhousing mount type starter is here.
Adapter
Starter used w/adapter
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 11-26-2012, 11:03 AM
THANK YOU !!!!! to C10 ,JUNIOR STOCKER and COBALT 327 for your replies to my question about starter mounting holes on an older 283. you have been most helpful. CRUIZINCOUPE.
Nova Emblem Template J-Garden Body - Exterior 5 10-09-2010 04:09 AM
Flame template glessen Body - Exterior 9 07-03-2010 04:25 PM
Club Website Template grapro Hotrodders' Lounge 11 11-29-2008 02:02 PM
Drilling Hole for Starter cc82z-28 Engine 14 06-25-2008 05:31 PM
Drilling block for mini starter 85Sierra Engine 10 03-08-2006 02:37 PM
