chev truck steering box - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2009, 01:29 PM
I am preparing for a power steering swap on my 1950 chev pickup to a later model power steering ( 70-80's 800 box ) and they recommend a 2wd box. I have a 4wd box and they look pretty similar. Does anyone know exactly what the difference is. I know they have different part numbers.
Old 07-21-2009, 02:16 PM
The big difference is that the 4x4 box only has splines around 1/4 of the sector shaft and the 2wd has splines all the way around with 4 missing splines each 90 apart.
Old 07-21-2009, 03:02 PM
As noted, the main difference is the output shaft. If you are buying a kit that has a pitman arm, the 2WD arm will not fit a 4WD box. If you are fabbing your own pitman arm, mate the outer end of the early arm with the steering box end of the 4WD arm.
Old 07-21-2009, 05:58 PM
Thanks guys -- That is the info I wanted and I had thought Joe's answer would be the way I would do it being as the 4x4 box pitman already points the right way. If I have to get a rebuilt I will look at the 2wd as the pitman choice is much greater.
Old 07-23-2009, 11:53 AM
fast68's Avatar
likes chevy trucks & boobies
just for learning's sake
the 4x4 guys convert to the 4x2 shaft andpitman arm when converting ot crossover steering on their rigs
i have parted billions of the 2wd full size truck boxes out for the 4x4 crowd over the years
so i snag up all 4x2 boxes i come across,
last week i found two
so it goes on..
haha
Steering Box Adjustment Custom10 Suspension - Brakes - Steering 10 06-12-2009 11:45 AM
steering box question: HELP choirboy Suspension - Brakes - Steering 21 12-13-2008 06:17 PM
Isuzu Power Steering box in 49-51 Mercs jrs Suspension - Brakes - Steering 2 02-11-2008 01:42 AM
Manual Steering Box sb72elcamino350 Suspension - Brakes - Steering 1 01-29-2004 11:07 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
