Chevelle 12 bolt axle spline count - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2004, 06:27 PM
JamesRS's Avatar
Hi all, could anyone tell me what the axle spline count is on a 72 Chevelle 12 bolt. I think it's 30, but I'm not sure. Don't want to take the cover off until i get new gears and a posi unit for it. ..... Also, just to confirm this... a truck posi unit should work okay, just not the pinion gear right?
Thanks
Old 10-22-2004, 06:34 PM
Tazz
As long as the pinion matches the gears you are all right...what exactly would be wrong with using a truck posi pinion? Find someone who rebuilds rear ends and ask them if there are different splines on the axle to be sure...get your info from a professional.
Tazz
Rat Rods Rule!
Old 10-23-2004, 02:42 PM
JamesRS's Avatar
Thanks for the reply Tazz,
The Truck pinion is a different size then a car pinion. It will not fit in a car 12 bolt housing. I was looking for confirmation about the axle spline count though. Thanks anyhow.
Old 10-23-2004, 08:43 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I looked up part numbers and only came up with a 30 spline count for car or truck.
Old 10-23-2004, 11:21 PM
JamesRS's Avatar
Excellent, Thanks M&M. Now on to find right gear set.
