Chevelle 4L80E Transmission Spedo Hook Up - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2005, 08:45 PM
I have a question about using a mechanical spedo in my chevelle along with the 4L80E Transmission. Can i use the stock spedo in my chevelle and hook it to the 4L80E? And if it can how do i do it or who can do it?
Just to give some back ground info. It's 1972 Chevelle. I have a 6 liter Chevy to put in and just looking for a transmission. I was thinking of using a th350 or 400, but with the fancy fuel injected motor i all ready have the wiring and computer that will also control the 4L80E (and i think 4L60E too) so why not go the extra step? Any options opinions on this would be helpful and the spedo is a large deciding factor right now.
Thanks All
John
Old 11-24-2005, 09:59 AM
72elcamino's Avatar
I had the same problem with my car. Bowtie Overdrives sells a box that takes the digital signal from the 4L80E and converts it to rotations in a small electric motor that hooks up to the speedo cable. Its called Cable X try this site. http://www.bowtieoverdrives.com/hot/
Old 11-24-2005, 12:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the 4L80E is not setup for a mechanical speed-O if you did not know that.
Visit this page for mechanical speed-O conversion. the conversion is not cheap to purchase
4L80e speed-O
Old 11-24-2005, 01:04 PM
Yeah i know that the 4l80e are not set up for mechanical, but i don't want to put in custom gauges cause i like the original look.
Thanks i didn't come across those sites when i was searching.
Thanks again
John
4L80E HD Transmission Gene Abbott Transmission - Rearend 0 10-31-2005 08:26 PM
4L80E Transmission 10 Spot Transmission - Rearend 2 08-24-2004 05:33 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
4L80E transmission Seon Transmission - Rearend 7 11-12-2003 06:59 PM
How to hook up torque converter clutch without a computer Roy Newton- exprotech Transmission - Rearend 3 12-28-2001 06:21 PM
