chevelle axle codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2005, 09:19 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
chevelle axle codes
I looked for axle codes on my friends chevell to see what kind of gears came in it but i couldnt find it. I thought it would be on the passenger side axle tube facing forward. I took a knife and scraped most of the dirt off (must have been an inch thick) but still couldnt find it. If anyone knows where i should look and a site that has the the decoded codes that would be very helpful. any help is appreciated.
Old 10-21-2005, 11:37 PM
It's usually a few inches out from the center section, and it might be toward the top of the tube. Scrape the major crud off, then shoot what's left with WD-40. Wipe it real hard with a rag until it's clean, then get up in there with a flashlight. It's not stamped real hard, so it's easy to miss.
Don't assume the code on the outside matches the gears on the inside after 30-some-odd years. They might not be original.
Old 10-22-2005, 10:52 AM
1969NovaSS's Avatar
chevelle axle codes
so it is going to be stamped. but my gear code lokes like it was cast into the axle tube itself. is that odd?
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
dropped axle on 64ss chevelle hot64ss Introduce Yourself 1 12-05-2004 09:01 PM
Accessory Codes 65 Chevelle mannboy General Rodding Tech 7 12-05-2004 04:47 PM
Chevelle 12 bolt axle spline count JamesRS Transmission - Rearend 4 10-23-2004 10:21 PM
Chevelle Axle Housing Bushings Rscarl Suspension - Brakes - Steering 8 07-29-2004 09:56 AM
