Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevelle instrument cluster housing color
Old 05-07-2006, 06:41 PM
maddjohnny maddjohnny is offline
I have several 69 Chevelle instrument clusters.
I am trying to restore the best one.
The outer plastic rear housings are gree and a little black around the edges.
I figure, when new, the housings were sprayed the green color. Sometime after they were installed, the underside of the dash areas were dusted with black. I am trying to find out what that green color is called? Does anyone know the name? or the part number? and most important . . . where i can find it???
Any help would be greatly appreciated!
Also . . . is there a trick to removing the clear plastic lens off the front? I don't want to break it.
