Chevelle Jolts into Reverse and Drive
Hi Guys, this is my first post on this great website, my current problem with my 1970 Chevelle is, to make this short I have my car idling at 850-900 in park when I put it in reverse or drive it drops too 750 is this normal? and when I shift into reverse or park the whole car jolts. now I ahve been messing with my idle and if I lower the trans does shift nicer but the lower idle effects drops my oil pump pressure and voltage at idle. So is there something wrong with some part of the trans? She shift fine when driving it just when going into gear, will these jolts hurt the transmission or rear end (i know it cant be good
) I dont know if it has a shift kit but it does have a 2000 or 2200 stall, Thnks guys for your help
Thanks for the reply, i there any specific things i should be looking for in the rear end and u-joints, how can i tell there worn?
Slack in the driveline in your case can be caused by ANY of the following.
Axleshaft splines. Spider gear splines. Spider gear teeth. Ring gear. Pinion gear. Universal joints. Driveshaft slip yoke splines. NONE of these are "easy" to check if you don't know what to look for, but you have a starting point now. We here at Hotrodders can help you though. Welcome.
| Car Will Not Go Into Reverse?? | HotRodMan | Transmission - Rearend | 15 | 05-22-2007 02:33 PM |
| th350 has only reverse | Merickk | Transmission - Rearend | 1 | 01-04-2005 02:07 AM |
| th350 reverse double apply??? | eskoskimo | Transmission - Rearend | 1 | 10-11-2004 05:07 AM |
| New TH 400 slow into drive and reverse | Jmark | Transmission - Rearend | 2 | 02-09-2004 10:39 PM |
| granny took a spin in my cousins chevelle to rescue the boat | shesmy63 | Hotrodders' Lounge | 7 | 08-11-2003 09:33 AM |
