chevelle or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2005, 06:12 PM
chevelle or not?
Why Don't They Consider A G-body Malibu A Chevelle? It Is The Same Frame As A Chevelle With Using Metric Measurements!!
Old 09-18-2005, 06:22 PM
Wiki Edits: 49
It's like the difference between a clone and an authentic car. One is real the other isn't.
Old 09-18-2005, 06:33 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
Ahhhh, A 78-88 is in fact a G-body while anything earlier would be an A-body. The two frames are not the same. Though they may be close the G-body is a stiffer frame than the A-body. The front suspension parts are not interchangeable and the rear ends are not without cutting and welding, otherwise it would be easier to put a 12-bolt in a G-body. I also think you will find a slight difference in width and length between the two.
Old 09-18-2005, 06:48 PM
poncho62's Avatar
Wiki Edits: 5
Originally Posted by 1982 SS
The two frames are not the same. Though they may be close the G-body is a stiffer frame than the A-body. .
I beg to differ...........maybe, the front is better, but......the rear of the G-bodys are garbage. The rear bumper is the crossmember, and they are prone to rusting.....badly.
Ontario Rodders
Old 09-18-2005, 07:21 PM
It was all just marketing geniuses at work. The original A-bodies in '64 were called Chevelles, and the fancy ones were Chevelle Malibus. Same thing with the Nova and Chevy II names. The Nova was the high-end Chevy II. In '69, the Chevy II name was dropped, and the Nova name was used, even on the el-cheapo models. Probably fooled a couple of dozen people with that one. I don't know if it was the same year, but they dropped the Chevelle name and called them all Malibus, again fooling the masses. Same thing with Bel Air, started fancy, ended cheap.
Old 09-20-2005, 07:51 AM
Here's another: Silverado
Chevelle vs. Malibu nitro3421 Hotrodding Basics 32 11-17-2012 05:37 PM
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 18 01-10-2011 07:44 PM
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 07:52 AM
granny took a spin in my cousins chevelle to rescue the boat shesmy63 Hotrodders' Lounge 7 08-11-2003 09:33 AM
chevelle handling dk01_99 Suspension - Brakes - Steering 5 03-06-2003 03:59 PM
