Chevelle only starts when I let off ignition - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2012, 07:29 PM
GreshamRoss's Avatar
A little background:
My 70' Chevelle has been sitting in paint for quite a while. In the mean time I removed the wiring harness and column along with other irrelevant items.
I replaced the ignition tumbler as the old one was broken. I also dissasembled the column, cleaned to clean up and paint. Everything seemed to go back together okay.
Today I made a trip out to start it and after screwing with it for a while (fouled plugs, etc) I finally got it to start, but only after I let off the key. It will crank and crank, but wont start. I let off the key to give up and it fires up. I tried it multiple times and the same thing happens.
Its a 350 with HEI and an auto. I had the power going to the BAT vs the IGN as I was in a hurry, could this have been the issue?
Could I have a bad ignition swith?
Its weird as it didnt do this before I took everything out.
Old 03-07-2012, 08:02 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
The ignition switch is on the steering column---right?
Might not have it adjusted quite right---The electrical part down near the bottom.
Or another option----might be a bad switch----not exactly sure how the 70 switch is wired for starting.
A quick fix for this--and all you need is a piece of wire about 3ft long.
You could attach this wire to the "R" position on the starter solenoid (providing your car has one), and splice it to the wire feeding the HEI.
Just tape it to the existing purple wire going to the starter.
Might double check---wire may already be there.
If HEI was added, it is possible that there were some other wiring issues done as well.
Up until HEI was standard equipment-(1976-1977??), GM used this method to
provide 12 volts to the coil when starting----when you let off the key to "RUN", 12 volts is no longer being fed.
It is also common for ignition switches to completely drop the IGNition and ACCY circuits when starting the car (ever notice the radio stops, and all the lights on the dash go out when cranking?)---Completely normal.
(This is the reason for the second small wire to the starter)
Don't feel alone in this----I have a forklift at work that does the same thing--seems I cannot get the correct ignition switch for it.
HEY---I think I've seen a pic of that car somewhere else----You on Team Chevelle???
Old 03-07-2012, 10:00 PM
Greg T's Avatar
www.krusinklassics.net
There is a resistor bypass wire that feeds full system voltage to the distributor when the key switch is in the start position. When the switch is released to the run position the resistor wire takes over. *There is no power in the bypass wire...broken wire, bad connection, bad ign switch.*
Old 03-08-2012, 06:49 AM
T-bucket23's Avatar
Wiki Edits: 26
In the case of an HEI you should not be using the resistor wire ever. Sounds like you dont have the hot in crank wire connected to the coil
Chet
Old 03-08-2012, 09:04 PM
Sure am. I came over here to get some technical help with a saginaw I picked up as folks over here seem a little more forgiving with those tranny's.
Old 03-11-2012, 11:36 AM
Well I went out and messed with it again and it starts normally now, didnt really change anything so not sure. Now the car wont idle right, but the carb has been sitting for 5 years so I will be rebuilding it (Edelbrock).
Projects are great
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 19 10-13-2016 04:14 PM
67 chevelle ignition problem/no spark in "on" position BlackStrat67 Electrical 26 03-18-2012 07:49 PM
72 chevelle ignition switch assembly problems customdrumfinishes Electrical 9 08-10-2006 05:06 PM
What happened to Ignition Man? - The good and bad of Ignition part brands Francis Electrical 4 04-25-2006 10:45 PM
1964 chevelle ignition switcch jaws651 Interior 8 08-13-2005 04:55 PM
