Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevelle outer rocker contour
Old 02-25-2013, 08:01 PM
diggers diggers is offline
take a cut off wheel slit the rocker on the bottom open it up to where the curve is out of it put a piece of metal in ther to fill the hole where you slit the metal. Thats about all you can do you buy junk you get junk
