doesnt matter
The qtr panel goes over that any way right? As long as the qtr lines up with the door who cares what shape it is . Its aftermarket? An old body man i learned from long ago used to say you cant see both sides of the car at the same time?
take a cut off wheel slit the rocker on the bottom open it up to where the curve is out of it put a piece of metal in ther to fill the hole where you slit the metal. Thats about all you can do you buy junk you get junk
#1 Check your parts fit on the origional. Then match it or better it. Whatever it takes.
I spent 2 days trying to make an aftermarket fender fit the aftermarket headlight door, and grill, and hood, and door, all at the same time. on a 67 chevelle. I ended up having to cut the fender into about 3 pieces, and re-shaping it then welding it back together. (was supposed to be the best you can get) |
You would think that with the popularity of the Chevelle, they could get these part right.
Nothing seems to go together correctly on these car swhen it comes to re-pops Had the same issues with a few of the 59 Chevy parts as well. Seems most of those parts were all 95% the size of actual original parts. |
| 69 Chevelle rocker panel removal | Wrencher | Body - Exterior | 74 | 02-25-2013 07:50 PM |
| 71 chevelle inner rocker panel replacement | race_jr | Body - Exterior | 0 | 07-04-2011 10:57 AM |
| Outer Rocker Work | modas | Body - Exterior | 3 | 11-01-2006 06:07 PM |
| Inner/outer rocker panel replacement question? | workingclass | Body - Exterior | 4 | 03-14-2006 07:03 AM |
| 99 Contour problems | cool rockin daddy | Engine | 2 | 04-18-2005 11:48 PM |
