chevelle Posi or Not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2012, 08:03 PM
hi guys i just recently got a 74 chevelle malibu 350, i wanted to know if it has a positrac, am a lil confused since if tires spin in different directions when car is lifted from rear its not a posi, or if you spin them and try to hold one and if one does hold its not a posi. i might be wrong thats why am asking lol, well i lifted the car from rear turn the car and put in drive both tires spin the same direction only one goes faster than the other, i hold the slower one and it stops spinning, but when i give it gas in drive both tires spin same direction and same speed. is it a positrac or not? thanks in advance...
Old 10-21-2012, 08:09 PM
poncho62's Avatar
Wiki Edits: 5
From what you describe......NOPE, not a posi
Old 10-21-2012, 08:17 PM
even though they both spin in same direction in drive? and giving it gas both spin same speed same direction
Old 10-21-2012, 08:50 PM
WDCreech's Avatar
Grumpy Old Goat Herder
If you don't believe poncho, jack one wheel off the ground, put the transmission in nuetral and spin the tire that is raised.
Old 10-21-2012, 10:13 PM
vinniekq2's Avatar
not posi,,,, get a posi carrier
Old 10-22-2012, 06:13 AM
big gear head's Avatar
High Performance Rear Ends
There is NO dependable way to test for a posi without taking the cover off and looking inside. If you have a posi and the clutches are worn then every one of these tests where you spin the wheels is going to give you a false reading. A posi with worn clutches will act like a standard differential when you jack it up and spin the wheels. On the other hand, if you have a standard differential that has been damaged from doing one wheel burnouts or if you have a bent axle tube then this will act like a posi when you jack it up and spin the wheels. As I said before, there is NO dependable way to tell without taking the cover off and looking inside. I know because I have been fooled by these things more than once. If you want to know what you have then take the cover off. You probably need to change the oil in it anyway.
Old 10-22-2012, 11:24 AM
vinniekq2's Avatar
If you have a posi unit with worn out parts that are so worn that it acts like none posi,then it "IS" none posi until it is repaired.You dont have posi,so repair or replace as required
Old 10-22-2012, 12:07 PM
I've seen a lot of limited slip differentials (posi) that would spin both tires hard under power, but when you jack it up and turn the tires they would spin in opposite directions. The clutches don't really have much pressure on them until you apply power to the differential. The majority of the pressure that is applied to the clutches comes from the pinion and axle gears trying to push away from each other when power is applied. The springs are there just to help get things started. Some people don't even install the springs when they tune the differential.
Then there is the Governor Lock, which doesn't apply any pressure at tall to the clutches until the wheel speeds become different enough for the governor to turn the cam plate and apply pressure to the clutch pack. It will always allow the wheels to spin in opposite directions when you jack the rear end up until you get the wheels spinning fast enough for the governor to kick in.
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 19 10-13-2016 04:14 PM
70 chevelle, olds rear, posi sometimes cletus van damme Transmission - Rearend 1 01-20-2012 06:26 PM
will a '69 Chevelle rear end fit into a '70 Chevelle? SMO'KUM UP Introduce Yourself 2 09-17-2007 07:15 AM
Non Posi to Posi-differential JeepStang94 Transmission - Rearend 7 02-28-2005 10:23 PM
posi for a 69 chevelle 66GTOguy Introduce Yourself 0 09-09-2004 02:42 PM
