Chevelle Power Steering Hoses??
So I have a engine swap from a 1990 chevy suburban 350 thats in my 1972 chevelle. I'm trying to get the power steering working, which is proving to be difficult, mostly trying to find a pressure hose to work for both the suburban power steering pump and the chevelle steering box. If I'm correct I will need a hose with a 16mm male end to go into the pump itself, then a 3/8 male end into the steering box (please correct me if I'm wrong). Then obviously a 3/8 return (which will be easy to find), any other input, tips, advice, or concerns would be great. Thanks in advance, Dustin.
You can get an adapter fitting for about $10. If you need new hoses they may have them premade also.
http://www.speedwaymotors.com/1964-7...nd-Pinion.html |
Thanks I'll check it out. I was gonna call my local hydraulic specialties tomorrow and see what they can do for me, but I thought I'd ask you guys.
I'm sure they can fix up a line for you. Just need the 16mm O-ring type fitting on Pump end of hose and 5/8" Inverted Flare on Steering Box end. :welcome:
| All times are GMT -6. The time now is 08:40 AM. |
