Chevelle Power Steering Hoses?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2010, 10:57 PM
So I have a engine swap from a 1990 chevy suburban 350 thats in my 1972 chevelle. I'm trying to get the power steering working, which is proving to be difficult, mostly trying to find a pressure hose to work for both the suburban power steering pump and the chevelle steering box. If I'm correct I will need a hose with a 16mm male end to go into the pump itself, then a 3/8 male end into the steering box (please correct me if I'm wrong). Then obviously a 3/8 return (which will be easy to find), any other input, tips, advice, or concerns would be great. Thanks in advance, Dustin.
Old 10-08-2010, 11:02 PM
SSedan64's Avatar
You can get an adapter fitting for about $10. If you need new hoses they may have them premade also.
http://www.speedwaymotors.com/1964-7...nd-Pinion.html
Old 10-08-2010, 11:30 PM
Thanks I'll check it out. I was gonna call my local hydraulic specialties tomorrow and see what they can do for me, but I thought I'd ask you guys.
Old 10-08-2010, 11:55 PM
SSedan64's Avatar
I'm sure they can fix up a line for you. Just need the 16mm O-ring type fitting on Pump end of hose and 5/8" Inverted Flare on Steering Box end.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Electronic power steering kossuth Suspension - Brakes - Steering 5 07-25-2008 06:44 PM
67 Chevelle power steering upgrade problem dans340s Suspension - Brakes - Steering 3 07-23-2008 06:51 PM
68 power steering burner Suspension - Brakes - Steering 5 04-06-2004 09:20 PM
Power Steering Hose Connections Larry D Suspension - Brakes - Steering 3 12-02-2003 08:06 AM
