Chevelle Rear size. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2006, 01:46 PM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
Chevelle Rear size.
Hi guys, its been a long time since I posted here. I have read the fourm often as I can. Im out here in sunny San Diego right now a long way from home but thats what the Navy will do.
Anyways im trying to find the lengths for the rear. Such as backing plate to backing plate. Anything I should know. The rear is for a 71 Chevelle. Im trying to find a 12 bolt rear and there is parts around here but my scrap book of things about my car sits at home and so does the car. So getting any lengths is a problem. Thanks guys it would be a lot of help.
Chris
Old 05-14-2006, 02:55 PM
MI2600's Avatar
Member# 3287
I don't know if this will help, but...
http://www.novaresource.org/axle.htm
Old 05-14-2006, 02:58 PM
406chevelle's Avatar
One of these days...soon
Measured across wheel mounting surface = 62" for the 64-77 chevelle.
Approximate rear end widths measured from backing plate to backing plate = 54"-55" for the 68-72 chelleve.
Stock center to center spring perch distance = 25" for the 68-72 chevelle.
Hope this helps out.
406chevelle
Old 05-14-2006, 03:26 PM
Thanks alot. I knew about the nova source but I wanted to make sure if that was in fact the correct size.
Thanks 406 thats just what I wanted to know. I didn't want to get a rear and then find out that it JUST won't fit cause there is an inch diff. and the tires rub now lol. That should be all I need. Always count on your guys here!
Chris
Old 05-14-2006, 10:45 PM
MI2600's Avatar
Member# 3287
When I bought my '72 El Camino, the seller said it had a posi 3.55. He was right. What he didn't tell me was that it was a pre-67 Chevelle rear, i.e. 1"-2" narrower than the '68 and up. Trust me...it still fits and works.
Old 05-14-2006, 11:10 PM
Yeah I knew about the 1 or 2 inch diff. I just wanted to know what was normal.
Would anyone happen to know how wide of a tire I could fit in the stock wheel well. Im looking at something around a 28 inch high tire. But want to know how wide I can go. There is no exhaust in there its free up to the frame rail. Thanks again.
Chris
Old 05-15-2006, 05:09 PM
If I remember correctly there is 13 inches between the back and the wheel well. I had a pretty large Goodyear eagle tires on before. Hard to tell. I think I will stay under 12 at the top because the tires will sit well below wheels wells and have enough room for movement in the body...
Chris
'66 Chevelle rear into a '69 69novarodr Transmission - Rearend 3 10-04-2005 07:22 PM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
71 Chevelle rear control arm bushings 454me Suspension - Brakes - Steering 4 04-23-2005 10:46 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 05:42 AM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 08:14 PM
