Chevelle SS gauge options? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2005, 10:08 PM
The dash I bought for my 71 velle came with 70 idiot light gauge pod(green instead of white numbering).
The official gauges are very expensive, has anyone ever used the guts out of a modern gauge and fitted it to a correct faceplate so it looks stock but is really say an autometer gauge?
If so who makes just the faceplates?
Old 11-28-2005, 02:51 PM
70 Chevelle SS 396
I don't know of any aftermarket gauges you could use for that (or I would do it too), but I've seen some "white faced" gauge stick-ons on ebay. Maybe the folks that make those could print you out some black ones that look like the original. That's about all I can think of. If those gauge faces weren't curved out around the sides, it would be a lot easier to fix. Good luck!
Nooj
Old 11-28-2005, 05:40 PM
Derkyb's Avatar
aftermarket guages
Take a look at how I did mine and see how you like it. It can be done with the old housing and lots of dremel work, plus fabricating some brackets but I think it will look ok.
Old 11-29-2005, 05:30 AM
70 Chevelle SS 396
Hey- that instrument panel looks great. I thought about doing my dash with aftermarket gauges- I imagined it would turn out looking a lot like the one you've done. Did you just leave the original clear lense off? What size gauges did you use for the speedo and tach?
It looks sharp-
Old 11-29-2005, 03:35 PM
Derkyb's Avatar
Speedo is 3 3/8 Fuel is 2 5/8 rest are 2 1/16. No I did not use the plastic lens. Good Luck
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
1970 El Camino SS Oil Pressure Gauge retrotruckparts Electrical 2 10-19-2005 07:08 PM
1971 Chevelle SS Stripes For A Clone. M&M CUSTOM Body - Exterior 8 09-23-2004 06:08 AM
Chevelle Malibu vs. SS Juggalette Hotrodding Basics 3 04-19-2004 05:31 PM
