Chevelle starter wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2003, 05:45 PM
Would anyone have a diagram for a 72 Chevelle/elCamino. I have to rewire the starer and have a red, purple yellow and black wire running down to the starter. The purple is for cranking ( I remember this from my alarm installation days). The red is constant power. The yellow should be for 12 volt to the coil when cranking and the black I would guess is a ground.
Can someone confirm the yellow and black? I dont want to ground a wire that carries power or the smoke will get out of the wiring harness and I know that if the smoke gets out, the wires don't work any more.
Thanks
Tom
Old 08-04-2003, 07:01 PM
1969Chevelle's Avatar
I don't know if this will help, but I can confirm the wire colors from a 1972 Chevy full size pickup wiring diagram: purple from the ignition circuit to the S terminal, yellow from the R terminal to the coil + terminal. And of course the battery cable to the B terminal.
The black wire you mention I am not sure about. Best thing to do is trace everything out with a multimeter. Then you won't have any surprises.
Ed
Old 08-04-2003, 07:41 PM
PrimeMover's Avatar
Sittin' on top of the world...
If I'm not mistaken, the smaller black wire had a big teminal end on it, and it went to the big main power lug along with the battery cable.
