Chevrolet 283 Engine - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 10-19-2006, 04:58 PM
I have a fully restored 56 Bel Air. Recently it started hesitating when cold or coming off idle. Checked all the basics, points, plugs, wires.
It is also popping back through carb now. This seemed to start and has gotten steadily worse. I really don't want to go into carb, 2 Barrel but am thinking that may be my next step. Suggestions ?
Old 10-19-2006, 05:19 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders. Best to ask in the Engine forum. But if I were you...I would double check my timing.
Old 10-19-2006, 09:15 PM
rj57's Avatar
If the timing checks okay, the carburator may need a re-build?
The 2bbl they bolted to the V8 265s, and 283s in 1955/6/7 are nothing to re-build. Any parts store should be able to supply a kit although you have to realize any kit you get now, will cover years 19xx - 19xx. (ex. 1955 - 1964)
Yes the kit will fit your carburator, it just won't be year specific like they used to be.
One thing to check for if the carb is an issue is gasoline in the oil. Pull the dip stick and smell it. If you smell gas, you have it in the oil cause the carb flooded. An oil change will be a good thing.
Old 10-20-2006, 10:59 AM
Buick Hybrid Guy.
Is it the stock engine? Has it been rebuilt?
If the timing is too far retared (set back) then it will act just as you've described...
If it's the stock engine I'd bet your cam's going flat. The oil today has been mandated to loose some of the old chemicals for emmissions that allowed flat tappet style cams to live. Now that the chemicals are gone alot of the older flat style cams are going flat. All new engines have roller cams that don't wear.
Timing first... that's the easy... then if it's ok... Go to the carb...
If it's too lean it'll pop back through the intake.
Start easy...
E-mail me anytime UR50SLO@aol.com
Hope that helps, Scott~
Old 10-20-2006, 02:12 PM
Thanks Scott, engine all new, have checked timing, right on the money. I'm thinking like you the carb is running too lean. May have something stopped up.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
Rebuilt Engine Squeaking, Driving me Nuts! BH69Camaro Engine 24 04-22-2005 08:51 PM
Verifying engine pedigree... johnnya Engine 3 08-04-2004 06:42 PM
283 chev engine mods Holden HG Ute Engine 10 09-26-2003 05:34 PM
