Chevrolet Limited slip pinion shaft removal, HOW??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2008, 08:10 AM
I have a 1979 Monte Carlo, had a bad 6-cylinder, put in a hot 350. Tires spin if you even look at the gas pedal, so I got a limited slip rearend for a steal. Before I put it in, I wanted to clean it up, paint it and of course replace the bearings and seals. I did all the cosmetics, then pulled the cover to get to the C-clips. Removed the little pinion retainer bolt, and expected the pinion shaft to come out easy, like it has for me in the past; however, the limited slip has the spring-retainer (I think that is what it is called, I Googled for an hour) and the pinion shaft will not slide out. IO tapped it a bit, and it simply will not come out, I wasn't about to start beating on it. I figured the Internet would be filled with simple "how to" diagrams and videos...it was, except for limited slip applications. Some sites (this one too) make reference to removing the parts in order to get to the C-clips, but those sites blow right past all the steps and merely say "remove the pinion shaft" or cross shaft. Help, please!! If thee answer appears somewhere on this site, I apologize, I've been looking for quite a while.
Old 06-15-2008, 12:23 PM
redlightning's Avatar
Are you sure all the bolt it out?
http://www.nastyz28.com/forum/showthread.php?t=107063
Old 06-15-2008, 01:07 PM
If you are sure the whole spider gear pin bolt ie... (pinion bolt) has came out, and the pin still does not want to come out. The pin is probably warped or welded itself to the spider gears from doing 1 legged burnouts. Been there done that, had to use a torch to cut the center part of the pin out in order to get the axles to slide in to get the C-clips out.
Old 06-15-2008, 01:41 PM
Having just gone through the broken bolt issue on one of these, does your pinion shaft lock bolt look like the whole one or the broken one in this picture?
Old 06-15-2008, 03:51 PM
Wow, how did you get the picture of my broken bolt?! It came out so easy I didn't even examine it, I guess they don't break when you are taking them out as much as they do from abuse (I bought the rear end in this condition). Mine has at least a thread or two left inside. I couldn't find my easy-outs, so I ran to the parts store and got a new set...I imagine the easy-outs should do it, but my fingers are crossed nonetheless. Advance Auto did not have the new bolt, so I imagine I'll be making a stop at the Chevy dealer and pay $7.50 for a 25 cent bolt. Thanks...I'll follow-up.
Thankfully, it looks like nothing is bent or fused as some feared.
Old 06-15-2008, 03:53 PM
It's amazing that I just had to deal with this same problem a day ago. You might want to read this thread:
Problem w/ 8.5" C-clip axle
By the way, the bolt was $4 at the chevy dealer. The pinion shaft was $44. Both were in stock.
Old 06-15-2008, 04:45 PM
If the remainder of the bolt doesnt wanna turn with like a dental pick on the edge of it. you might take a small propane torch n heat that spot on the carrier n try a pick again.... it should come right out..Them bolts are supposed to have red lock tight which will require heat(not cherry red either) to remove easily. On another note if you do decide to go the easyout method i would drill the hole for the easyout with a left handed drill bit.
Old 06-15-2008, 05:39 PM
Jmark's Avatar
Agreed, sometimes the lefty drill bits will zip the broken bolt right out without needing the easyouts.
Old 06-15-2008, 06:15 PM
I read about the lefthand drill, and was going to give it a try (hardware store was closed). I will try the dental pick first, then get some left hand drills, and borrow a 90 degree drill... the hole is just a little low to get at it with a regular straight drill.
Thanks for all the advice.
Old 06-23-2008, 05:45 PM
Amazing how many times this bolt is broken. I used the kit from www.fabbriassociates.com. www.etoolcart.com also carries it and I think they're cheaper.
Anyway, the kit worked great in like 10 min. I will never be caught without one of these again! No fuss, no damage!
Good luck.
Auburn limited slip posi jacobm99 Transmission - Rearend 2 01-25-2004 08:13 AM
68 Camaro 10 bolt & 2000 truck limited slip 68CaliCamaro Transmission - Rearend 6 12-22-2003 04:57 PM
how much? 3.73 limited slip rear end...junkyard search. Rubberman2003 Hotrodders' Lounge 8 07-06-2003 09:32 AM
Ok, question on limited slip... Rubberman2003 Transmission - Rearend 5 06-07-2003 04:47 PM
Want to go from 2:43 limited slip to 3:73 limited slip Bradless Transmission - Rearend 2 01-03-2003 10:12 PM
