Chevrolet SSR rearend swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2005, 09:13 PM
Hey rodders, I'm seeking your experience. I recently purchased a new Chevrolet SSR limit slip complete rearend with 373 gears. I am thinking of putting it in my 48 Plymouth Business coupe. Have any of you had any experience with this rearend and considerations I should be aware of? I have worked on many old car projects over the years but this is my first shot at starting a street rod project.
Thanks for your thoughts
George
Old 10-18-2005, 12:17 AM
I think it is safe to say that not many people around here have had much to do with those rear ends.
Could you post up some pictures and measurements?
Old 10-18-2005, 05:04 AM
pictures & measurements
I'll work on this, this comming weekend. This rearend with disk brakes is most likely rare, so they're probably not many out there. It sure looked appealing and complete.
George
Old 10-18-2005, 05:09 AM
astroracer's Avatar
It's about as rare as any full size GM truck rearend with disc brakes... I hope you didn't pay a premium because it was out of an SSR.
The chassis/suspension is pretty generic to the regular trucks.
Old 10-19-2005, 06:51 AM
GoneNova/406's Avatar
they were originally suppose to come out with 6L motors in them and i understand that they finally are coming out with them now so they should stand up to a gould amount of stress.they are so new that there probably isn't all that much info out there yet.
Old 10-21-2005, 12:04 PM
SmallBlock_guy's Avatar
Gmt368
The Chevrolet SSR is the GMT368. This is based largely on the GMT360 which is the trailblazer and trailblazer SS. The rear end is almost identical to the Trailblazer. The measurement and dimensions should be similar.
As for the powertrain. The original 5.3L (LM7??) was/is replaced by the 6.0L (LS2). The better ones are the manuals. I believe they have a 3.73 also but there was a push to use a 4.10. If I remember correctly there was an issue with axle shock.
rearend swap for a nova nova63and66 Transmission - Rearend 10 11-10-2005 06:34 PM
rearend and axle swap Suckingas Transmission - Rearend 1 03-03-2004 05:37 PM
1969 Camaro Rearend Swap josh7681 Transmission - Rearend 8 01-02-2003 02:44 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
