Chevy 1 barrel carborated - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2013, 11:35 PM
How do l go about adjusting the screws at the bottom of the carb? I mean as going all the way in and how many turns out if anyone would know it'd be greatly appreciated. Thanks
Old 03-10-2013, 11:44 PM
Niko
does it turn over and idle? if so start by getting the idle right id say anywhere from 8-1100, do that by slowly adjusting the idler screw. need more info about the set up
Old 03-11-2013, 12:00 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Unless you have a radical motor, 1100 rpm is excessive. Start by turning the idle mixture screws out 3/4 to one full turn for starters, adjust your idle screw as you go, turning it in or out to get good idle quality.
For more help we need more information on your setup.
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
PontiLac (03-11-2013)
Old 03-11-2013, 01:09 AM
Used Core Rochester R1 Carburetor 17059014 1778 1979 GM Truck 292 250 6 Cyl | eBay
This is the carb that's on my truck. I need to know about the bottom screws next to the base of the carb, where to reset them. I know how to set the idles. If this helps it's for a 1980 gmc truck 1 ton 292 thanks
Old 03-11-2013, 01:23 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
That looks like a combination idle mixture screw and anti dieseling solenoid. Start with it turned out about one full turn and go from there.
Semper Fi
fordss (03-11-2013)
Old 03-11-2013, 02:29 AM
I been watching videos on youtube, how to tune carbs. People are saying to set your rpm at your recommended rpm for your vehicle, their saying to turn one screw all the way out to the point it picks up rpm. And do it to the opposite one as well, but keep bringing it back down to the recommended rpm after each screw has been set. Is that the way to do it? Thanks
Old 03-11-2013, 02:48 PM
so is this true or not
Old 03-11-2013, 03:34 PM
RWENUTS's Avatar
Your carb only has one mixture screw.
Turn the idle down as far as possible. Turn in the screw slowly till the motor slows down or runs a bit rough then back it off till it runs smoother.
Slow your idle down if it sped up and adjust again if needed.
The Following User Says Thank You to RWENUTS For This Useful Post:
fordss (03-11-2013)
Just bought 78 Camaro Z28, quesiton on changing 2 barrel carb to 4 barrel Juicer28 Engine 8 06-10-2011 03:47 PM
Swap 2 barrel with 4 barrel Q-jet 1972 Nova 350 Varn Ford Engine 3 02-14-2010 12:59 PM
fuel injected to carborated joshlee90 Hotrodding Basics 2 01-02-2009 04:23 PM
5.0 camshaft (carborated) FAIRLANE DUDE Engine 4 07-27-2004 04:45 PM
Can I replace two barrel carb with four barrel on chevy 305 maverick19642001 Engine 6 02-20-2004 11:00 AM
