chevy 10 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2002, 06:12 AM
Wink chevy 10 bolt
Hi there;
I need to the backlash for a chevy 10 bolt rear end in a '89 1/2 ton p/u
I've changed the third member bearings and have
.007 backlash now.Is this good or bad?
5.0 killer
kenneth
Old 03-21-2002, 01:36 PM
Talking
Kenneth'
your .007 backlash is fine for your truck, if you just plplaced the bearing, before you button er up I would just quickly ck your tooth pattern on pinion to confirm proper pinion position. Hope this helps out.
NOVA JEFF
Old 03-21-2002, 07:48 PM
Post
2nd that. .007" is acceptable
Old 03-22-2002, 03:19 AM
Post
[quote]Originally posted by NOVA JEFF:
<strong>Kenneth'
NOVA JEFF </strong><hr></blockquote>
Thanks Jeff that is the info I was looking for.
Checked tooth pattern already. Pinion depth is ok.
5.0killer
Kenneth
Old 03-22-2002, 03:23 AM
Post
[quote]Originally posted by reddwarf:
<strong>2nd that. .007" is acceptable</strong><hr></blockquote>
Thanks Red Dwarf for the confirmation.
4.0killer
Kenneth
