Chevy 10 Bolt carrier - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2002, 11:45 PM
Post Chevy 10 Bolt carrier
Howdy Folks, I have a 1986 Chevrolet 4X4 with a 10 bolt differential. The gearing is 3.08 and it has a lot of slop in the spider gears and after pulling the cover to inspect I've noticed a great deal of slop (clearance)between the pinion shaft and the carrier. The spider gears also move up and down about .060 - .080 when the pinion is moved forward and backward. The ring and pinion seem fine without any noise.Broken locking screw also.
Questions: Is this carrier junk from the description or can I repair it with a set of spider gears, shims and shaft? Is this common with the locking differential/ Thanks Megmar
Old 07-07-2002, 05:50 AM
axle bastard's Avatar
you're killin me buck!
Post
sounds like the friction plates in your locker are whooped. if indeed you have that type of locker. if you have an older eaton unit, i wouldnt wast my time with it. auburn makes a good replacement.
[ July 08, 2002: Message edited by: axle bastard ]
[ July 08, 2002: Message edited by: axle bastard ]</p>
