Chevy 10-bolt Differential Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2010, 02:17 PM
I did a search and couldn't find a previous thread, so here's my question.
I have a 51 Ford F1 with what I think is a mid-70's Chevy Nova differential.
I crawled under the truck and found three numbers. Reading them upside down with a flashlight, on the right front side, as you face forward, "GM32" Then on the right side of the axle tube also facing forward "1254333" and lastly on the right side up on the differential "F1A9" This last one was very difficult to read.
It does have 10-bolts.
Does anyone know what differential I have?
Thanks
Old 06-02-2010, 02:23 PM
ericnova72's Avatar
More for Less Racer
Look here for axle identity from both pictures and #'s. www.novaresource.org
Old 06-02-2010, 06:34 PM
I found another number.
2PJ G198 2
I think it means the rear end was made by Detroit Gear and Axel on the 168th day of the year during the 2nd shift.
The 2PJ should indicate the gearing and if it is a positraction. I can't find any site that lists a 2PJ.
Old 06-02-2010, 08:45 PM
big gear head's Avatar
High Performance Rear Ends
It could be from one of the other X body cars, Apolo, Ventura or Omega. Have you tried here? http://www.novas.net/forums/forumdisplay.php?f=14
81 chevy 10 bolt to 72 chevy 12 bolt campracing Transmission - Rearend 7 11-02-2009 11:14 AM
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 09:19 PM
7.5 chevy 10 bolt 411 gear tsve058 Transmission - Rearend 3 04-30-2007 07:58 AM
How to identify the year of a Chevy 10 bolt rear End? frankenvette Transmission - Rearend 2 04-07-2005 11:14 PM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 09:02 PM
